reset timestamp when event accured
hi
i have a event that handel 4 button and in timeout block draw online chart with clock and date on X axis,
every thing is ok but when i press a button and event accuerd tme reset to 1994 ...
why?
my code here... i read information from some global var(in attachment)
please help me for correct this problem
thanks.
(4,204 Views)
Accepted by topic author meysam_b
Hi meysam_b,
You need to wire through all data in every case in the event structure.
Repeat this for every wire that goes through a shift register.
The fast way to do this is to link the tunnels. Right-click the output terminal then use the Linked Input Tunnel menu to establish a link. After you choose Create & Wire Unwired Cases just click on the associated input tunel and LabVIEW will create the links for you automatically.
This should fix the resetting time stamp.
(4,161 Views)
hi nickf
thanks man! it's worked and I learn a new thing from you. thank you again for your clear answer and for your time.
(4,153 Views)
