resetting compactrio programmatically
If you don't want to/can't use the Reboot Controller VI, then there is no direct way to do this that I know of.  The RT can restart as soon as it is reset if you have a start-up exe on the controller.  To my knowledge, the FPGA cannot automatically reset itself however.  This is why I suggested to put your entire FPGA code into a loop so that it can effectively reset itself by looping back to the beginning of the code as soon as it resets the RT.  Hope this helps.
Message 11 of 11
(750 Views)
