resize the microsoft calender in labview
Dear friends,
I using microsoft calender in my application through labview.Im using the calender in IPC which is small size...
so im in need of change the size of calender.
Is it possible?
kavitha
kavi
Message 1 of 14
(6,745 Views)
  Dont you like this much size?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 14
(6,743 Views)
hai kavi ,
        i ve seen ur doubt about calender on (6.1.2010). u can resize the container and u can see more month in one window but u can't zoom a single month.
regard
sathish j
maximus_sjc42@yahoo.co.in
Message 3 of 14
(6,723 Views)
 friends,
Sorry a change in my question iwant to enlarge the calender size
I attached the calender picture i want to enlarge that only.
kavi
Message 4 of 14
(6,720 Views)
  Do you want to enlarge the picture only or what?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 5 of 14
(6,707 Views)
I don't think you can.  That is either a windows dialog box that is being called, or it is a VI embedded within LabVIEW that you will have no access to in order to modify it.
Message Edited by Ravens Fan on 01-06-2010 01:01 AM
Message 6 of 14
(6,706 Views)
 Hi krishna,
I want to enlarge the calender box why because im using it in a touch screen monitor .This calender box is quite small so its
difficult  to  use .
kavi
Message 7 of 14
(6,687 Views)
  I dont think you can increase the size  of that calender box.Just right click on the control and set time to now which will set the time to present time.But you can create your own timestamp control using some other calender which will change during the run time.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 8 of 14
(6,678 Views)
How to use some other calender with my timestamp?
kavi
Message 9 of 14
(6,669 Views)
Accepted by karpaga
why dont you use an Activex to create the calendar and resize to what ever you want to...See the attached vi
Guru
Regards
Guru (CLA)
Message 10 of 14
(6,641 Views)
