result value in digits full screen
With the example that I posted? You're probably being limited by the font that you've selected. Some fonts don't scale beyond a certain point. Try a different font.
As I indicated, you can also use a picture indicator, though I think replacing the numeric indicator with a string indicator will probably be easier for you.
Message 11 of 23
(1,916 Views)
Set it to font size 36.  Then hold Ctrl = until it grows as big as you want.  Or use a property node to write a large font size to the NumText.FontSize property.
Message Edited by Ravens Fan on 11-30-2009 10:27 AM
Message 12 of 23
(1,916 Views)
ctrl =    does not work with increase the size
since my keyboard has no direct =  sign i must put a shift to it to get a =  sign
by doing so i get a help window
So ctrl shift =  is help window  ( meaby he is sensing i need helpSmiley Wink)
Message 13 of 23
(1,906 Views)
Isn't it next to your backspace key?  What kind of odd keyboard are you using?
If you go to the dropdown for Fonts then size, the shortcut for Larger says Ctrl+=  meaning control and equals together.
If you can't do it by using the keyboard, then I suggest using the property node method.
Message 14 of 23
(1,903 Views)
Well normal european keyboard  thinkpad T42 P
and = is not next to back space
property node also does  not work -
I get 2 differant type´s
Message 15 of 23
(1,897 Views)
Hi RavensFan,
look here for German/Austrian/Swedish/Spanish (and a lot more) layouts...
But for me Ctrl-Shift-0 is still increasing font size Smiley Wink
Message Edited by GerdW on 11-30-2009 05:35 PM
Message 16 of 23
(1,890 Views)
I can not see the problem. Did you try my solution?
The short cut for going directly to font dialog is Ctrl+0 (must be selected first). Then you can type in the number you want in the font size box
Else, my = is shift+0. So in order type in Ctrl+= I must type Ctrl+(shift+0). But as said before. Not all fonts are scalable as the TTF type fonts
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 17 of 23
(1,876 Views)
Property node on what? I don't see any property nodes on the VI you uploaded. Which control are you trying to make large? The scale? If so, which part? The km/h indicator?
Message 18 of 23
(1,872 Views)
yes the    Km/h
Message 19 of 23
(1,866 Views)
Accepted by cees10
pfffff
problem solved!
Message 20 of 23
(1,855 Views)
