retain intermittend value
ok, attached a vi, for the interested reader.
Message 11 of 19
(1,011 Views)
like so, works as a concept. I did 2 options, keep for 10 iterations and timestamp. If someone wants to use the snippet
Message 12 of 19
(1,011 Views)
Ah, what a mess. You certainly don't need a stack of loops for any of this. See if this can give you some ideas....
(What if there is a new value and it is the same as the previous value? Wouldn't that require a time update?)
Message 13 of 19
(998 Views)
thanks!
this is why I want to keep it for 1 s only. Sometime the master does not send a write for a few seconds and then continues again. This way I recorded that behavior as well.
This is why I put 2 things to try, timer and just count 10 iterations since last value change, then reset the latch. 1s will be enough, anything we log is in 1 s steps, so can reference things nicely. PLC and everything else in the line only cycles about 1 s or so anyway. Some of the read registers change, the response is 1 cycle later only anyway.
Message 14 of 19
(992 Views)
Why not write the Read and Writes to separate tables? The Write should just have the Timestamp and Value.
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 19
(980 Views)
because then I have to merge 3 tables. Its much easier if they all run at the same frequency. I made it so the timestamp in SQL does not have milliseconds. Then I can align all the tables at full seconds. I just need to know what events are happening when. Can be hours worth of logs in 1 s intervals. And on top of it there could be the modbus log, which is endless as well
Message 16 of 19
(972 Views)
ok, did this
-if nothing is read, then set to 65535
-if something is read, put into shift register and send to SQL
-for 1.1s check if next array is empty, send content of shift register to SQL
-for 1.1s if some new value is read, populate shift register and send this to SQL
getting the result I wanted. Timestamp matches
time to go home.
Message 17 of 19
(948 Views)
It is is hard to judge a highly truncated image, but...
  • shouldn't the shift register be initialize with 65535?
  • Why all these coercion dots?
  • To get the first element, you don't need to wire the index
  • It seems incorrect to look at the first element of an empty array.
  • We cannot tell what's in the other case of the case structure or why there are two output tunnels.
Message 18 of 19
(941 Views)
-coercion dots because anything modbus is 16 bit unsigned
-the array is sometimes empty and sometimes its not. Because the modbus read happens at least once per second but the write just at random
-the 65535 is in the false statement. The first few lines in the SQL do not matter anyway, have to start the vi first and then start the modbus sniffer
thanks for all the help!
Message 19 of 19
(933 Views)
