return errors dll Labview
i would like to know how can i return the errors which i can have in my dll developped in CVI, because when i realize my dll in CVI in a Labview RT environnement , i can't use messages popup or Excel library.
Can you give me ideas,
TheGAme
(2,761 Views)
Hi TheGame,
You can use the Call Library Node function from within LV.  Simply make sure that the CVI code function returns a value (example: int functioname (typedef value1, etc) ).
You can send the values to the function and it returns a value linked to an error code.  For instance, 0 = no-error, -1 = bad error, etc.  You can also return messages, such as +1 = function completed, etc..
Ooops, I'm getting carried away 😄
The Context Help provide adequate information on how to wire the Call Library Node.  You can do a search on the function as well.
JLV
(2,751 Views)
