09-06-2005 07:09 AM
09-06-2005 07:18 AM
09-06-2005 07:25 AM
this is what I tried:
I am currently trying the same thing with the Waveform Min/Max ... Looks more promising than this 🙂
09-06-2005 07:28 AM
So you used the wrong express vi.
Have a look at this example.
Hope this helps.
Thomas
09-06-2005 07:35 AM
that easy ? ![]()
well, well 🙂
Thank you ...
Do you know by chance why my upper example doesn't work ?
09-06-2005 07:45 AM
It would have worked, if you had converted the dynamic-data to a double before you pass it to the > / < operators.
If you pass two different data types to a function, the "lower" is converted to the higher (e.g.: sgl -> dbl) which is why the dynamic data is passed on to the or-operator.
Just see this example.
Thomas
09-06-2005 07:59 AM
oh thank you .. 🙂
now I see 🙂
