Find out the peaks and check them against a value
Hi
I am currently aquiring a bunch of signals (4 to be exact) through a 6120 card. This works as expected.
Now I'd like to check all 4 signals if any value (up to 80 000 samples / waveform) has it's lowest level above -0,8 V and it's highest level below 0,8 V.
I tried this with the Express VI (Level and Amplitude Measurements). I check both for the peaks and if one of them (OR) is above/below that value, a Boolean value should change.
So I have my 1D - Waveform Array as Input  to the Express VI. I then get the Positive/Negative Peak. I wire those to smaller/grater sign. and when I try to wire the two outputs of the smaller/greater signs to an "OR", LabView won't let me 😞
It says: Source is Dynamic Data, Sink is Boolean.
What am I doing wrong ?
(2,885 Views)
Which Express vi are you using? Could you maybe post your code or a picture (please no bmp) of it?
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,876 Views)
this is what I tried:
I am currently trying the same thing with the Waveform Min/Max ... Looks more promising than this 🙂
(2,874 Views)
So you used the wrong express vi.
Have a look at this example.
Hope this helps.
Thomas
Using LV8.0
(2,871 Views)
that easy ? Smiley Surprised
well, well 🙂
Thank you ...
Do you know by chance why my upper example doesn't work ?
(2,869 Views)
It would have worked, if you had converted the dynamic-data to a double before you pass it to the > / < operators.
If you pass two different data types to a function, the "lower" is converted to the higher (e.g.: sgl -> dbl) which is why the dynamic data is passed on to the or-operator.
Just see this example.
Thomas
Using LV8.0
(2,862 Views)
oh thank you .. 🙂
now I see 🙂
(2,858 Views)
