reusable function inside vi
Hi All,
I am working on a front panel with multiple input controls(rings and textboxes). I want to set  the availability of the proceed button based on the values of the input controls. My idea was to validate the input when the value of one of the input controls changes. Is it possible to write the validation code only once and hook it to multiple events (input controls value change) ?
Thanks in advance,
(3,613 Views)
Accepted by topic author svh
If you use an event structure for it, you can have several events using the same event case.
If this VI is used as a dialog, you can configure multiple Value Change events from different UI sources for one event case (use the blue + Add Event button).
If this VI is a subvi, you will not be able to work like this as passing parameters does not fire the Value Change event....
Norbert
Norbert
Expert: Geometry
(3,606 Views)
Another option is to place your "input controls" in a cluster (cluster borders can be hidden).
One Event case covers any change.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,580 Views)
I bundled the value changed event of all the input controls to one event case.
It works perfect, thanks.
(3,529 Views)
