reverse in rows in a 2-d array of string
hello
I have a kind of simple question.but i tried many things and couldnt help.I need to reverse a 2-d array of strings in rows.just to make it clear i make an example:
a b c
d e f
g h i
and i want to make it
g h i
d e f
a b c
how can i do this?
Message 1 of 8
(5,085 Views)
A for Loop that autoindexes through the array row by row, then builds it back up in reverse order using Build Array and a shift register.
Message 2 of 8
(5,081 Views)
aputman
Message 3 of 8
(5,075 Views)
@aputman wrote:
Way too Rube-esque.
Bill
CLD
(Mid-Level minion.)
Message 4 of 8
(5,065 Views)
@billko wrote:
@aputman wrote:
Way too Rube-esque.
Because this is a simplified form of OpenG where there is an option to reverse by columns....hence the extra code.  My bad.....sheesh. Smiley Happy
aputman
Message 5 of 8
(5,055 Views)
@aputman wrote:
@billko wrote:
@aputman wrote:
Way too Rube-esque.
Really?  I would've just used the method described by RavensFan and stuck a transpose 2-D array before and after the loop.
Bill
CLD
(Mid-Level minion.)
Message 6 of 8
(5,047 Views)
Accepted by .mohamad.mah11
Here's what I would do.
Message 7 of 8
(5,039 Views)
Haha that should've occured to me because I first tried what you have there without the transpose 2d arrays and noticed it was doing columns and not rows.
Bill
CLD
(Mid-Level minion.)
Message 8 of 8
(5,031 Views)
