Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results forÂ
Search instead forÂ
Did you mean:Â
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
reverse iteration
reverse iteration
kmo
Member
‎01-09-2006
09:37 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is there any way to do reverse iteration using labview??
I want to use the index values of for loop which is executed frm 10 to 0 with a step of 1.
any help will be really appreciated.
kmo
0
Kudos
Message
1
of 4
(3,831 Views)
Reply
Re: reverse iteration
Evan
Active Participant
‎01-09-2006
09:39 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
There is no direct way so you just need to add a subtraction to the loop. Take the highest count and subtract out the i of the loop and there you have a reverse iteration.
0
Kudos
Message
2
of 4
(3,820 Views)
Reply
WNM
Active Participant
‎01-09-2006
09:39 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
This exact topic was covered recently in this
thread.
0
Kudos
Message
3
of 4
(3,819 Views)
Reply
johnsold
Knight of NI
‎01-09-2006
09:40 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Subtract i from N on each iteration and use the result. Search the archives. This was discussed last week.
Lynn
0
Kudos
Message
4
of 4
(3,817 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
