reverse iteration
Is there any way to do reverse iteration using labview??
I want to use the index values of for loop which is executed frm 10 to 0 with a step of 1.
any help will be really appreciated.
kmo
(3,858 Views)
There is no direct way so you just need to add a subtraction to the loop.  Take the highest count and subtract out the i of the loop and there you have a reverse iteration.
(3,847 Views)
This exact topic was covered recently in this thread.
(3,846 Views)
Subtract i from N on each iteration and use the result. Search the archives. This was discussed last week.
Lynn
(3,844 Views)
