reverse string order
Hi all,
i want to first reverse the order of the string first  e.g. the string is FDE7 9200  i want to change it to 0092 E7FD . further more i want to change this hex value string into decimal string.. ... i implemented them in my vi ...although the first part is working fine but i cant get the value to conver into a equivalent decimal number ...Vi is attached ..plz have a look
with regards
ali asad
Regards
Message 1 of 20
(7,525 Views)
Message 2 of 20
(7,517 Views)
In your input string, in the front panel, right click and change the type to Normal Display and then enter the input string. This will solve your problem.
Message 3 of 20
(7,515 Views)
I think the op will get hex values and needs to convert them and not display them. I think...
Message 4 of 20
(7,512 Views)
Message 5 of 20
(7,510 Views)
Muks can you show the results in the front panel.
Message 6 of 20
(7,506 Views)
Message 7 of 20
(7,497 Views)
mathan,
anything u feel is wrong in it?
Message 8 of 20
(7,495 Views)
MUKS, in your front panel, the reversed string shows 00297EDF where the whole string is reversed, but the OP wants this one 0092E7FD
Message 9 of 20
(7,485 Views)
I need to pay more attention i guess. Thanks for that correction
Message 10 of 20
(7,482 Views)
