reverse string order
Message 11 of 20
(3,263 Views)
You can convert the hex string to byte array and do the further manipulation.
Message 12 of 20
(3,262 Views)
Yeah including the space reverses in string. So i had actually accidently suggested the right way in the beginning. LOL!!!
Message 13 of 20
(3,259 Views)
But nothing from op so far...............
Message 14 of 20
(3,244 Views)
thank you all
but unfortunately i am still where i was started .. you see i am getting my input from serial port which is 4 byte of data , baudrate 57600 . I am getting the data from serial ..... in the front panel i change the display option to "hexadecimal diplay". but when i give this output to the hexadecimal to number blk it gives me a big fat zero.......
 i also tried the string to byte aray ...but it gives me output as an array of decimal equivalent of each byte saperate ...eg. if the input to it is 0A9E8BAA......it gives me the out as a 1 D array with  values 10,158,139,170 but i need  that thte output shd be the equvilent to 178162602....the decimal equvilent to 0A9E8BAA
regards .
Regards
Message 15 of 20
(3,206 Views)
Accepted by topic author nolsqn
To get 178162602, all that you have to do is type cast the string to a U32.
Message 16 of 20
(3,201 Views)
nolsqn wrote:
thank you all
regards .
As dennis as suggested, you need to do some sort of conversion. What you are doing just viewing it as hex. You can also view it as "****" but it is not getting converted.
Message 17 of 20
(3,172 Views)
thank you dennis it worked perfectly fine
Regards
Message 18 of 20
(3,130 Views)
Have you checked the 11th post? That didn't solved your problem?
Message 19 of 20
(3,112 Views)
The string reversal is not required. Not sure why the op even asked for that.
Message Edited by Dennis Knutson on 12-30-2009 09:04 AM
Message 20 of 20
(3,109 Views)
