right click in diagram mode -selection offset
When  using an extended display and right clicking on a object in the diagram mode, the selection is offset to the other side of the screen. Is this something that is fixable in lab view?
(1,030 Views)
This is a bug that appears when using multiple monitors of different resolutions, with the Context Help being open on an other monitor than the one where you right-clicked:
https://forums.ni.com/t5/LabVIEW/Menu-Offset-bug/td-p/3926066
(984 Views)
yes that worked perfectly thank you
(959 Views)
