Hello everyone, I have a problem with this program. Can you help me please
Message 1 of 17
(2,542 Views)
Please attach your code and describe your problem. We cannot debug the images.
https://tmesystems.net/
Message 2 of 17
(2,535 Views)
Hello ghada12,
We cannot run the images and also there is no information on what this code is expected to do and what this code is doing.
There is no enough information to answer your unasked question.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 3 of 17
(2,516 Views)
the purpose of this code is to detect the temperature from a sensor, if the temperature is above 25 or below 22 it must alert the user. I will use an ICP DAS module as a microcontroller
Message 4 of 17
(2,509 Views)
le but de ce code est de détecter la température à partir d'un capteur, si la température est supérieure à 25 ou inférieure à 22 il doit alerter l'utilisateur. Je vais utiliser un module ICP DAS comme microcontrôleur
Message 5 of 17
(2,508 Views)
Thanks for sharing the code, Still your Problem is not mentioned.
1. Are you measuring the Temperature as expected (I dont think because you connected the return count for the temperature Indicator.
2.In both the Cases you have mentioned ATTENTION, Are you concentrating only on the Boolean/on the Message.
Message 6 of 17
(2,493 Views)
Icône de validation par la communauté
Que me suggérez-vous comme correction s'il vous plait ?
Message 7 of 17
(2,483 Views)
Please do not accept as solution if your query is not answered, You can kudo a post you found helpful or insightful.
Follow the Community Guidelines NI user Guidelines.
I hope you need to understand the LabVIEW Basics before getting into the problem.
Also still you have not mentioned your Actual Problem (Is the Problem with Measuring temperature Value/Displaying Graph or Showing Alert to user? where you got stuck?
if you are able to provide the problem statement clearly, we have to go with guess.
Message 8 of 17
(2,442 Views)
I helped you there. Can you please accept my answer as solution?
Message 9 of 17
(2,377 Views)
I have to say that I am deeply displeased with your current path of supply BS answers and asking for credit.  If you can explain to me how this helps the OP instead of just simple code substitution for something that already works, maybe I'll consider retracting this statement.  Otherwise, don't try for cheap kudos and solutions.
Bill
CLD
(Mid-Level minion.)
Message 10 of 17
(2,364 Views)
