Hello everyone, I have a problem with this program. Can you help me please
The OP did not save the code for previous version.
Message 11 of 17
(1,107 Views)
Salut @ghada12,
Est ce que tu pourrais expliquer en detail qu'est qui se passe? C'est tout ce que les gens veulent savoir.
Merci!
Grck5000
Message 12 of 17
(1,105 Views)
Accepted by topic author johnalia
Message 13 of 17
(1,070 Views)
From the picture, your Visa resource is empty. Your report file path is empty too.
Both probably need a reasonable value, right?
(Also, there is absolutely no reason to maximize the front panel and diagram to the screen)
Message 14 of 17
(1,058 Views)
please can you modify my VI
Message 15 of 17
(1,055 Views)
No, because we don't know your hardware.
Message 16 of 17
(1,045 Views)
Hello Ghada12, my friend
what hardware or device are you using to connect to LabVIEW? If you can share that info and maybe your code as well, it would be helpful for us to help.
but make sure your file path and visa resource are not empty as mentioned by Mr. Altenbach.
so 1. know what hardware/device you are using.
2. Know what com port your device is using. This can be checked if you open device manager.
Message 17 of 17
(1,037 Views)
