rising slope array
I am trying to find a solution for splitting arrays. I have data from a graph going into an array. It has 360 measurements. X is Degrees and Y is Force. Since its like a positive sine waveform pattern on the graph, I want to create some sort of rise and fall detection so that each positive sine waveform gets seperated into a new array until it detects a negative slope and so on for the next ones. I could use slope function to detect a positive slope but I dont know how I could use it together with split, index and build array.
Any ideas?
(5,233 Views)
Hi rvkamat,
Wrong wording. You have data going from an array into a graph…
Calculate derivative?
Then you should try to "split, index and build array" with a test VI. Once you know how to "split, index and build" arrays you can combine this with your "slope" VI…
(5,222 Views)
Accepted by rvkamat
Taking the derivative will give you the slope.  From there, you can easily find the indecies for when the slope changed directions.  Then use Array Subset with those indecies to make up your new arrays.
(5,183 Views)
Thanks. Its a little bit complicated than that since I dont know if there is a positive slope or negative slope in the beginning or it could even start from the peak.
So I need to check a slope with the derivative function (I implemented it), then stop when there is a negative slope so that I get a Positive Sine Waveform (works) , take the array subset from the index I find (I am having trouble with Arrays but I will figure it out)...I need to do this 6 to 7 times
(5,164 Views)
If you get stuck, post what you have so far and tells us what you don't understand.  We are usually pretty good at giving nudges in the right direction.
(5,142 Views)
Thanks crossrulz. Smiley Happy
(5,115 Views)
