Showing results forĀ
Search instead forĀ
Did you mean:Ā
rotate a chart graph
i want a chart graph rotate  90 degrees but i do not how Smiley Sad
have  somebody a idea?
thanks
(3,497 Views)
Use this
(3,489 Views)
thanks
but dosen“t work for me
cause i use a Chart Graph and this is XY Graph
have someone a idee?
(3,453 Views)
Found this while adding it to the idea exchange:
Give the idea kudo's and it might someday be implemented.
For now, you need to convert the data to XY data, where all  Y values form a ramp form 0 to Number of samples.
(2,923 Views)
