Showing results forĀ
Search instead forĀ
Did you mean:Ā
rotate cursor in graph
I am a newbie for Labview. I am using Labview 8.2. I want to detect the peaks ( in realtime )in XY graph, mark them dynamically with cursors  ( each cursor will display the "y - axis" value as well as a particular name ( to be picked up from database or external file , depending on the X-axis value ...X axis is time).
Cursor is displayed horizontally. As the peaks are very close to each other , these cursors are overlapping on each other. To avoid this, I want to rotate these cursors by 90 deg, so that they are displayed vertically.
Hope , I am clear with my querry.
Nilesh
Message 1 of 10
(7,823 Views)
Look at attached pic
Right click on cursor legend, select Attributes>> cursor style and select as shown
Dev
Message 2 of 10
(7,806 Views)
Nilesh,
You can try using the cursor properties for the same. Please see the snapshot and the VI attached.
Dinesh
Certified Labview Associate Developer(CLAD)
Don't Forget to Rate the answers.!!! You can do it in few seconds
Message 3 of 10
(7,800 Views)
Nilesh,
Dinesh
Message 4 of 10
(7,799 Views)
Thanks for your response, but i think I was not very clear about what I want to do . I want to rotate the Name of cursor by 90 deg. Kindly see the Picture attached. Hope it would clear the my intentions
Message 5 of 10
(7,793 Views)
Unfortunately, the cursor text is not passed through as a reference; so, you can't get to a vertical arrangment property.
Might I make another suggestion though:  try using annotations (new to 8 or 8.2 not sure).  The annotations are very similar to cursors, but the label can have an offset programatically controlled.  You can also use an arrow to point to the feature.  By doing this, you can prevent them the text from overlapping.
Chris Megdanoff
Certified LabVIEW Architect
Message 6 of 10
(7,782 Views)
Through that is not possible, you shift a cursor name slightly to the right of the cursor point, by giving spaces before the cursor name in the cursor legend
Message 7 of 10
(7,774 Views)
Dev
Dev, Is the feature available in LV 7.1 ? I cant see it in the way you ve shown. Am I doing anything wrong ?
- Partha ( CLD until Oct 2027 šŸ™‚ )
Message 8 of 10
(7,766 Views)
It was available, Partha
I remember that property being accessed a bit differently in LabVIEW 7.1
Message 9 of 10
(7,728 Views)
This is an example of how to do advanced cursor tasks in pre-LV 8.
This thread is an old collection of interesting threads that includes the above plus many others.
Ben
Message Edited by Ben on 04-23-2007 07:54 AM
Message 10 of 10
(7,723 Views)
