Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
rotate diagramm
rotate diagramm
michaelrittner
Member
10-08-2003
10:58 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
hi
i use labview 6.1
how can i rotate a diagram (90°) and how can i change the axes ?
0
Kudos
Message
1
of 2
(2,409 Views)
Reply
Re: rotate diagramm
Mads
Active Participant
10-09-2003
02:21 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I think the only way to rotate the diagram would be to rotate the monitor...:-) It's recommended that you code from left to right. What purpose did you have in mind?
There is no zoom function.
Mads Toppe
Check out our Modbus Test Master - developed in LabVIEW
0
Kudos
Message
2
of 2
(2,409 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
