rt - debug startup executable
is there a way to debug subVIs within startup executable VIs?
(2,774 Views)
Write what you want to debug in the subVI, save the stuffs in a txt or tdms data on rt. And then build the app.
Your question depends on what do you want to debug.
(2,764 Views)
Have you taken a look at the LabVIEW help article: Debugging a Stand-Alone Real-Time Application (RT Module)?
If you follow these steps you should have no problems debugging the subVIs within a startup executable.
Stephanie A.
Americas Marketing Manager
(2,750 Views)
