Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2
run code simultaneously
Re: run code simultaneously
Dennis_Knutson
Knight of NI
06-29-2005
01:13 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
That will work but an even easier way is to save a VI with a .vit extension. This is a VI template and every time you open a template, it creates an new instance. No need to do any copying to a different name and then deleting.
0
Kudos
Message
11
of 12
(694 Views)
Reply
Ramin_E
Member
06-29-2005
01:22 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Yes, you are correct except when exiting or quitting the program, it will complaint to save (the * effect). My method does not.
0
Kudos
Message
12
of 12
(691 Views)
Reply
2
All Forum Topics
Previous Topic
Next Topic
