run time change # of radio button and boolean text
By default radio buttons show labels.
You can not change label of control in run-time, only caption or boolean text.
Message 11 of 18
(1,377 Views)
PS, no, radio buttons show boolean text. Just link to the button inside radio-button-cluster.
Message 12 of 18
(1,375 Views)
You can't change the Boolean text of the Booleans in the radio button?
Message 13 of 18
(1,373 Views)
That would solve my problem. How do you link to a button?
Message 14 of 18
(1,371 Views)
How do you create or link the property node to control? The same way.
Select control (button), right click it, Create -> property node.
OR
Put or copy Property node, Right click - "Link to", navigate to button inside radios
Message 15 of 18
(1,362 Views)
the attached example shows how to change the boolean texts and the caption texts inside a radio button control. Obviously the labels are not changeable in runtime, just hide them.
Edit: this is a generic approach, which covers all booleans inside a radio buttons control. Use it if only the reference is available (e.g. access to a radio buttonc ctl. in another VI etc.), or if all texts must be altered at once.
Sorry, I haven't seen the other approch in Message 12 in the first place, it is more streight forward. So use it, if the control is placed in the same VI.
Message 16 of 18
(1,352 Views)
Can you reinitalize default values of a radio button after program is complete? I tried to do this with an invoice node but received an error
Message 17 of 18
(1,339 Views)
Hi labking33,
I guess You mean an invoke node. Yes, it works - I've put an invoke node into the stop-button value-change event node, to try out.
Did You link the node to the radio button control or did You wire a reference to the invoke node? Maybe the reference became invalid before the invoke node has been executed.
I'm using LV2011, if that info may help for debugging.
Message 18 of 18
(1,334 Views)
