run time engine 7.1
I am trying to install the ELVIS system on multiple computers. LabVIEW 8.2 has already been installed on all of the computers. I am trying to install the CD that accompanied the ELVIS as well as the PCI card. However, when I install both of them and try to run ELVIS an error comes up on all the computers with "Unable to locate the LabVIEW Run-Time engine"
please help, thanks
(3,187 Views)
Also I tried to uninstall both LabVIEW and ELVIS and neither shows up in the add/remove program
(3,185 Views)
When you tried to unistall LabVIEW and ELVIS in your Windows Control Panel, did you make sure to select the National Instruments folder under the list of programs first?  Also, do you have any other National Instruments software installed on your computer?  If you navigate to the National Instruments folder in Control Panel and still do not see your LabVIEW software, please e-mail or call into support.  We will be able to send you a special utility which will remove your software even if it doesn't show up in Control Panel.  It sounds like this issue would be fixed by a reinstallation.  Thanks!
(3,160 Views)
