Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How can I change the Picture Item of the Boolean programmatically?
Andrey_Dmitriev
Trusted Enthusiast
01-16-2008
11:39 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi!
A very simple question.
I can change any picture item for boolean control (pressed, hover, etc):
The question is: - how to do this
programmatically
(in RunTime)?
Is there simple way to do this?
Thank you in advance,
Andrey.
0
Kudos
Message
1
of 4
(3,767 Views)
Reply
Re: How can I change the Picture Item of the Boolean programmatically?
Eugen_Graf
Active Participant
01-16-2008
11:51 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I think it's not possible, but you can use picture ring for this.
LabVIEW Portal
1
Kudo
Message
2
of 4
(3,763 Views)
Reply
TCPlomp
Trusted Enthusiast
01-16-2008
11:53 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Sorry,
you can't you could bypass (some of the issues) with my
Boolean XControl
Check my
demo code
, showing a lot of icons for one boolean control.
Ton
Free
Code Capture Tool
! Version 2.1.3 with comments, web-upload, back-save and snippets!
Nederlandse
LabVIEW user groep
www.lvug.nl
My LabVIEW Ideas
Tags:
xcontrol
View All (1)
2
Kudos
Message
3
of 4
(3,761 Views)
Reply
Andrey_Dmitriev
Trusted Enthusiast
Author
01-16-2008
12:17 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks, Ton!
This one nearby exactly what I needed. Very good starting point for me.
Andrey.
0
Kudos
Message
4
of 4
(3,747 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
