How can I change the Picture Item of the Boolean programmatically?
Hi!
A very simple question.
I can change any picture item for boolean control (pressed, hover, etc):
The question is: - how to do this programmatically (in RunTime)?
Is there simple way to do this?
Thank you in advance,
Andrey.
(3,771 Views)
I think it's not possible, but you can use picture ring for this.
(3,767 Views)
Sorry,
you can't you could bypass (some of the issues) with my Boolean XControl.
Check my demo code, showing a lot of icons for one boolean control.
Ton
My LabVIEW Ideas
(3,765 Views)
Thanks, Ton!
This one nearby exactly what I needed. Very good starting point for me.
Andrey.
(3,751 Views)
