run time engines
If you have several runtime engines installed, will  the executable pick the correct RTE to operate correctly?
ie@ I have several executables developed using different versions of Labview. The code is locked, so I can't open it and save it using the latest version of labview. If I call these executables using Testand 3.5, will they run correctly if I have the correct RTE for each installed?
(3,468 Views)
They should.
(3,466 Views)
Each executable will find its own runtime engine. The runtime engines are installed in different folders under National Instruments\shared\LabVIEW Run-Time.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,464 Views)
Accepted by L_V_Developer
Hi L_V_Developer,
Thanks for the post.
Just to confirm all the points,
Both LabVIEW runtime engines will exist separately, and the target machine will be able to run the executable using the runtime it was built with. You can install as many runtime engines on a machine as you would like, and they will not interfere with one another.
For example:
If you want to send someone a LabVIEW executable built on LabVIEW 8.6, and they are already utilizing LabVIEW executables built with LabVIEW 6.1. The new 8.6 LabVIEW runtime engine will exist next to the older LabVIEW 6.1 runtime engine on the target machine, and nothing will be overwritten or conflict.
Note: The version of the run-time engine must match the version of the LabVIEW development environment the executable was created on. For example, an executable created in LabVIEW 5.1 requires the LabVIEW 5.1 Run-Time engine to run. The exception to this is with minor LabVIEW revisions (e.g. a LabVIEW 7.1 executable can be run on the LabVIEW 7.1.X Run-Time engine).
This obviously indicates that the run-time engines are not backwards compatible, e.g., LabVIEW Run-Time Engine 8.5 cannot run executables made in LabVIEW 8.2.1.
In order to check which run-time engines you already have installed to your PC, browse to the following directory:
C:\Program Files\National Instruments\Shared\LabVIEW Run-Time
In that directory, you will find a different folder for each version of run-time engine that you currently have installed onto your system.
Let us know if you have any problems,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,459 Views)
OK, now for the second part of my question. If this works for LAbview. Will it also work for Teaststand and Labwindows/CVI?
(3,430 Views)
Hi There,
Are you calling executable's from Teststand and CVI?
If so, then Im not sure what would have changed. If not, then make sure you setup the abView Module Adapter (Configure-->Adapters...-->LabView) correctly.
Message Edited by Hillman on 02-02-2009 04:44 PM
Kind Regards
James Hillman
(3,418 Views)
