runVI invoke structure issue when application is developed in XP and tested on server 2003
Hi all,
I'm using LabVIEW 8.6 + DCS.  I just created an application on XP and after that I started do some test on Server 2003. One part of my code is done by using runVI invoke nodes and subpanels. When I run my code in server 2003 it just freez. I don't even get any error messages. When I try to run my code on probe mode it might sometimes start but sometimes not. Does anyone else have noticed this kind of behavior? Is there any way "tune" server 2003 to accept code which is developed in XP(or other operation system)?
I know that server 2003 is not supported operation system. Still most of my code modules works perfectly on server 2003...
BR, Jim
(2,729 Views)
Can you post a subset of the code that demonstrates the problem? Are you running a standalone app or the development system on Server 2003 machne?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,711 Views)
