svx_Override DAQmx Parameters.vi
I am using the PXI&PCI 4461.
in svx_Override DAQmx Parameters.vi,  there is a max value [V] and min value [V]  setting in the "input configuration"
how to setting the values?
if i set a value that  smaller than the real input signal,  is there any error will be occured?
Message 1 of 1
(2,392 Views)
