runtime error when adding a softmotion axis
Hi Matt,
Keep me updated if changing the NI-RIO fixes that error. Thanks!
Mychal F.
Applications Engineer
Message 11 of 25
(3,111 Views)
Hi Mychal,
Sadly the error persists. Would upgrading to SP1 be likely to mend this issue?
Matt
Message 12 of 25
(3,106 Views)
Hi Matt,
I don't think upgrading to SP1 will solve the issue. Just to clarify, you are running LabVIEW 2010 (not LabVIEW 2010 SP1) and the SoftMotion Module 2010 f1 correct? Also, can you please post a screen shot of the error? Thanks!
Mychal F.
Message 13 of 25
(3,101 Views)
Thanks again Mychal,
I'm running labVIEW 2010 f2 rather than SP1. Attached are screenshots of the process which causes the error and the error message itself.
Matt
Message 14 of 25
(3,094 Views)
And softMotion 2010 f1.
Matt
Message 15 of 25
(3,092 Views)
Hi Matt,
Do you get this error when you try adding any new thing or just the NI SoftMotion Axis? Can you try adding a new variable to see if this error occurs then as well?
If you only get the error for the SoftMotion axis, can you try making a simulated axis? You can do this by right clicking on My Computer>>New>>SoftMotion Axis in your Project Explorer window. Are you able to create the simulated axis?
Thanks!
Mychal F.
Message 16 of 25
(3,078 Views)
HI Mychal,
I can add a new variable, but can't add a simulated axis without crashing labVIEW.
Cheers,
Matt
Message 17 of 25
(3,069 Views)
Hi Matt,
What operating system are you running this on? Also, how did you uninstall the 2011 software (go through the control panel, delete files, etc.)? Thanks!
Mychal F.
Message 18 of 25
(3,051 Views)
I'm running Windows 7. I went through control panel>>uninstall a program>>National Instruments Software.. and then uninstalled all NI products.
Matt
Message 19 of 25
(3,049 Views)
Accepted by canonball
Hi Matt,
We were able to reproduce this issue here, so the Product Support Engineer filed a Corrective Action Request (CAR) for you. The CAR number is 336637.
However, you can reinstall the 2011 software and it will fix the issue for you (LabVIEW, Real-Time, FPGA, SoftMotion, RIO, etc.). I know you had downgraded to 2010 in order to get the Trajectory Generator API, but there is a way to get this in the 2011 software. Please reference the fifth post in this thread in order to get it on your palette.
Please let me know if it will be possible to reinstall the 2011 software. If it isn't, we can work on trying to find you a workaround. Thanks Matt and sorry that you are having so many problems with this!
Mychal F.
Message 20 of 25
(3,040 Views)
