sampling channel & displaying on same graph
Hello everyone,
i have a question that should be often meeted  , but that i don't know how to solve.
i sample x channels that can be  1 to 10 for example, so my state machine scan like this ch1,ch2,ch3......ch1,ch2,ch3.
My probleme is that if there was few ms betwwen each channels i couls admit they have all same data of acquisition and
waiting all channels reading and ploting them (on "ring " chart)  at same date time, but here
delay between channel is 3s minimum up to 10 s.
 What kind of way should i adopte :
for moment i tried two ways but not satisfing:
1) at each channel acquisition i remember all other channels for this date time, so i obtain a graph with many flat moment between each cycle .
and the more channels i have the more they look square
2) i put a Nan value for aquisition for channels not concerning by current aquisition, this way is much close that i want to obtain , the probleme
is this method is that between real acquisition plots the chart cannot draw a line between them and i have for result a curve a multicolored
dots not linked and too hard to interpret
So my question is is there a third or fourth solution ?
in attachement images to illustrate the probleme
Best regards Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,220 Views)
Hi Tinnitus,
3rd option:
Make each channel a single xy-plot keeping track of it's DAQ timestamps! Plot all "tracks" on a XY-graph...
(3,217 Views)
You can create a XY graph like this
If you put the same x-axis, you will have synchronous Y-axis. If you want to see the timestamp you can replace index by the vi Get date.
Regards
(3,183 Views)
Sorry, i think i don't express correctly, i will try to make an vi example to
clarify my problem
regards
Tinnitus
(3,173 Views)
