04-29-2005 10:57 PM
05-02-2005
04:56 PM
- last edited on
03-05-2025
04:07 PM
by
Content Cleaner
I think you're on the right track:
I think these ideas should get you started.
One thing to keep in mind though, is with measurements where you are trying to find phase differences, you would be better using a simultaneous sampling board (Such as NI's S-Series Boards). A typical DAQ device (such as your USB device) multiplexes the signals onto an Analog-to-Digital chip. That means that each measurement is going to slightly out of phase with the next. If your system is large or the vibrations propagate slowly, this shouldn't matter; however, if you have a more quickly moving signal you may want to consider getting a different DAQ device for the most accurate measurements.
05-03-2005 10:59 AM
05-04-2005 06:52 AM
05-04-2005 06:52 AM
05-05-2005 01:52 AM
