sampling rate of NI PXI 5152 digitizer
hello friends.
with ur help now i am able to make my software for controlling NI PXI 5152 digitizer and NI PXI 2503 multiplexer.
now in my project i have to keep display change rate for each temperature indicator (i am going to monitor 24 monitoring points)
on front panel window to 2 sec/change.
so sampling rate of digitizer and multiplexer should be accordingly.
but i have some dought regarding some topologies:
1)sampling rate of digitizer
2)record length
3)number of samples
above three things i have to mention for accurate synchronization of multiplexer and digitizer.
Can any one please explain me these three terms?so that i can decide what should be the value of them.
thanks in advance.
vishal sakarvadiya
(2,661 Views)
     Here are some links that will brief you about these terms:
1. Sampling rate,samples: tuotrial
2. Record length: Knowledgebase, tutorial
Here is one good comprehensive page to learn all your fundamentals: http://zone.ni.com/devzone/cda/tut/p/id/3408
Hope this is what you were looking for!
Message Edited by Shreyas on 01-08-2010 09:28 AM
Shreyas Hebbare
Shreyas Technologies
India
(2,642 Views)
