save data in tdm if button is pressed
To save my data in TDMS file each time I pressed the button "Save data". I created the VI attached.
My VI worked fine but When I opened the file I found my data, in addition  columns of zero , Cause in the fault case of  my Condition structure I selected use the default value if it's not wired.
I would appreciate your help
Thank you in advance
My best regards
Nadia
(4,025 Views)
Accepted by k.nadia
1) You need to wire the TDMS reference and error wire through the FALSE case
2) You have 1 too many items in your channel list array.  Delete element 0.
(4,020 Views)
Thank you
The solution is so simple, but I didn't see it Smiley Frustrated
(4,013 Views)
I few a couple more bugs.
1) The Reshape Array has the size elements swapped.
2) You might want to use Create Or Replace for the TDMS Open.  Otherwise you will just be adding more data to the file.
(4,007 Views)
Hai guyz,
I apologize for using this wall to ask but i went and used a sumilar design for my saving funtion. However when i saved, the whole data was saved in a single column. why is That?
Newbie92
(3,844 Views)
You reshaped the array into a 1 x 2 instead of a 2 x 1 like the example above showed.
(3,834 Views)
Hai RavensFan,
LOL. That did the trick. Thanks 🙂
Newbie92
(3,824 Views)
