save it to ms.word
Hey marp84,
In the context help for the Word Send Document VI it says:
"Sends the current document to a list of recipients via email. You can use this VI only if you configure Microsoft Outlook or Outlook Express as the default email application.
If you do not, the VI places the message in the Outlook output box but does not send it to the recipients. If Outlook is not installed on the computer, the VI returns an error."
Do you have Microsoft Outlook on your machine and have it set as the default email application? As mentioned in the context help for this VI, this could be the cause of the error you are seeing.
Hope this helps.
-Ben
WaterlooLabs
Message 11 of 23
(1,868 Views)
Yes I've Microsoft Outlook in my machine.can you help me how to make it set as the default email application?
tanx
Message 12 of 23
(1,854 Views)
Microsoft
For email, you also have the functions on the Data Communication>Protocols>SMTP Email palette.
Message 13 of 23
(1,850 Views)
where i can get email palette?
Message 14 of 23
(1,845 Views)
It's installed with the full version of LabVIEW.
Message 15 of 23
(1,842 Views)
Hey marp84,
There are several ways that you can email documents using LabVIEW. In addition to the Report Generation Toolkit and the Word Send Document VI, there is the SMTP palette as mentioned by Dennis. Also, there is a way to use and existing Gmail account and LabVIEW to email documents. Check out some of the following links for some examples on the SMTP vi's and the Gmail routine:
Gmail using LabVIEW
Send SMTP email from LabVIEW 8.6
Also, check out the rest of the email examples on ni.com/community
Hope this helps.
-Ben
WaterlooLabs
Message 16 of 23
(1,818 Views)
how i can save it to another folder at directory for example e: ?
Message 17 of 23
(1,782 Views)
Copy.
You keep asking VERY basic questions. Have you gone through the LabVIEW tutorials?
Message 18 of 23
(1,770 Views)
If you only want to past a Labview indicator/control into say a lab report you only has do this. Then in edit mode(the VI is not runningjust select one or more labview items and copy them (Ctrl+c). Then go back to word and paste the selected items in (Ctrl+v). If you want a runtime snapshot just use the print screen button. If you need to edit, you may use paint
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 19 of 23
(1,768 Views)
can you tell me how i can renam x and y axis?
Message Edited by marp84 on 08-08-2009 02:01 AM
Message 20 of 23
(1,733 Views)
