The following VI is a short version of a larger VI where I have two "double [64 bit real]" inputs (DBL wires) that I am trying to save into the same file. Here I just substituted them with two random value generators. What I'm getting so far is both measurements saved on the same column in a spreadsheet, but I'm trying to separate them into two columns to do further analysis in Excel. Do you have any suggestions?
Thanks in advance,
Valls
