05-19-2008 06:09 AM
05-19-2008 06:12 AM
05-19-2008 06:14 AM
Dear Ton,
How to open fp in a hidden state? Could u please explain in bit detail.
Mathan
05-19-2008 06:23 AM
Why don't you do the following:
1 - connect the Subvi graph to an output.
2 - on the parent vi, connect it to another graph indicator and hide it
3 - save the graph by the same method that you already use on the subvi
4 - delete the procedure for saving the image that you have on the subvi (since it's not needed anymore)
05-19-2008 06:35 AM
05-19-2008 06:37 AM
05-19-2008 06:43 AM
05-19-2008 08:17 AM
05-19-2008 08:25 AM - edited 05-19-2008 08:25 AM
05-19-2008 11:33 AM - edited 05-19-2008 11:35 AM
@Mad_Bob wrote:
OK, can someone provide example code of 'pulling a front panel into memory'.
Bob.
