saving extended data
I've recently built a vi that reads voltages from a photodiode, plots them on a graph and then saves them to a text file. Everything works fine, apart from the saving. The graph displays the data correctly, but when I save it only writes to 10-3 rather than the full extended value. How can I fix this?
(3,591 Views)
Accepted by 1LabViewNewbie1
There is a coercion dot appearing at the input of the 2-d array which makes me wonder as to what is the representation of the data from the 2-D array.
You can manipulate the format input on top of the subVI to specify how to convert the numbers into characters. Have a look at the Detailed Help of the subVI. Also, I would recommend posting the code so we can understand the issue better.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,589 Views)
Hi
You problem is quite common 😉 In your labview environment activate "show context help" by typing Ctrl+h, then place the mouse pointer over your "Write To Spreadsheet File VI" Select detailed help. Emphasize on the format input.
Good luck
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,581 Views)
