sbRIO 9607 does not appear in NI MAX
Hi Sam,
Update: I still stuck with the same problem. I have check drivers version compatibility at the link https://www.ni.com/en/support/documentation/compatibility/09/software-support-for-compactrio--compac.... There is no issues on the version compatibility (it requires version 2015 and current) since I use LabVIEW 2019. I reinstall the NI CompactRIO drivers and try again. Even I reinstall all LabVIEW with the modules and try again. But, its still cannot work. I also try to connect the sbrio with other computer and I get the same problem. I really don't know what to do Smiley Sad Please help me
#I attach with the NI MAX shows all the modules and compactRIO driver.
Message 11 of 26
(2,000 Views)
Show ALL of the software branch of the tree in MAX.  There is a lot of stuff below where your picture cuts off.
Message 12 of 26
(1,986 Views)
Hi Ravens,
I attach all the software in NI MAX. Please advise me
Message 13 of 26
(1,975 Views)
I need help from this forum. Please..why the sbrio cannot appeared in NI MAX.
Message 14 of 26
(1,929 Views)
I was hoping I'd see something in your latest screenshot (thanks for including them) that would be something obviously missing or a wrong version, but nothing is jumping out at me.
I hope others following might have some ideas.
Message 15 of 26
(1,917 Views)
Hi, pattern!
Could you, please, check if the firewall is enabled on your Ethernet interface? Could you disable it for a test, and then try to discover sbRIO using MAX?
Message 16 of 26
(1,910 Views)
I have disable the firewall and test again. I ping the ip address using command window. In NI MAX the sbrio still not appear under Remote System. Then I try create new remote device in NI MAX ( as per attachments). But, I get notification said "The device at this ip address is not supported by the driver installed on this host". I have installed the required drivers, but why it say not supported? I use Ethernet cable to connect the sbrio with my pc (host). Really need helps from expert in this forum.
Btw, sbrio 9607 compatible with LabVIEW 2019 right and should be no issue?
Message 17 of 26
(1,899 Views)
I checked your screenshots and noticed, that your sbRIO and PC have the same IP address -169.254.194.105 (this situation causes a IP address conflict). You have to change your PC IP address  (for example, set it 169.254.194.106).
Message 18 of 26
(1,897 Views)
I change my PC IP address to 169.254.194.106. But, now I get error said "Unable to Initialize connection to remote target".
Message 19 of 26
(1,893 Views)
Update: I have follow this thread https://forums.ni.com/t5/LabVIEW/Unable-to-use-MAX-to-connect-to-remote-PXIe-8840-running-RT/td-p/28.... From this thread, it solved by change the NI MAX version. How to know the compatible MAX version with the sbRIO? Currently I use NI MAX 19.0
Message 20 of 26
(1,891 Views)
