sbRIO 9607 does not appear in NI MAX
And now try to ping sbRIO IP. Because before that you were pinging your PC IP via loopback (your PC has the same IP you were pinging, so it said nothing about connection to sbRIO)
Message 21 of 26
(1,353 Views)
Hi Sam,
Done ping the ip sbrio. But, I get the same error
Message 22 of 26
(1,349 Views)
I still cannot solve the problem
Message 23 of 26
(1,318 Views)
Was this issue resolved?  I'm having the same problem today and it is with a system on which I have been using with a sbrio 9607.  The new device just doesn't show up in NI MAX.
I love the forum, but all too often the issue goes private and we never see the resolution.
Message 24 of 26
(1,229 Views)
I troubleshoot the issue directly with NI support staff and they figured out that my board has a problem. So, I send for a repair (under warranty) & the issue is solved.
I suggest you contact directly with NI support staff.
Message 25 of 26
(1,224 Views)
For all future readers of this topic I would like to add:
When I initially connect the sbRIO to the PC (which is properly configured because it *can* detect other sbRIOs), the sbRIO-9607 still does not always appear in MAX.
I then have to reboot the PC and the sbRIO will show up after this.
Message 26 of 26
(1,049 Views)
