sbRIO-9651 onboard Temperature
Hi
I am using NI sbRIO-9661 SOM and I have a problem with it's temperature. I don't have an appropriate cooling system so it rises, and in order to avoid accidents I want to programmatically measure it's onboard temperature. The temperature is visible in NI MAX, but I can't find it under FPGA I/O (in case of other RIO boards Chassis Temperature is visible). Can I somehow track the temperature.
Best Regards
Edgar|CLAD
(2,901 Views)
Accepted by topic author edgarvardanyan1999
Hi edgar,
using a simple internet search I found this one as first search result…
(2,884 Views)
