sbRIO (cRIO) reboots into safe mode (software error)
Hi there,
I've used the sbRIO-9612 for year on the project, recently it sometimes reboots into safe mode. In MAX I may find the status of the sbRIO is "Safe Mode with software error". Can anyone tell me, how can I find out where is the problem. I have the error log as attachment.
Wilbur
Message 1 of 9
(7,486 Views)
Message 2 of 9
(7,483 Views)
I read again the log file. There're something that should help:
Exception code: 0x00000700
Thread ID: 0x02E270B8   Thread name: niserial
Thread stack base: 0x02E270B8  stack size: 32768
Call Stack:
0x1de9170+0xe93cc: _dtors () in module niserial.out
0x1ddd83c+0xdda98: _dtors () in module niserial.out
0x1dc840c+0xc8668: _dtors () in module niserial.out
0x1df3a34+0xf3c90: _dtors () in module niserial.out
0x1db2154+0xb23b0: _dtors () in module niserial.out
0x1dc6a2c+0xc6c88: _dtors () in module niserial.out
0x1dc68a0+0xc6afc: _dtors () in module niserial.out
0x1dc67b0+0xc6a0c: _dtors () in module niserial.out
0x3dbc80+0x8: Virtual function table for __cxxabiv1::__si_class_type_info () in module 0x0
Message 3 of 9
(7,464 Views)
Here is the program for controlling the serial port on sbRIO.
(The missing subVI is used to build up the frame for communication. The wait until 3ms was added according to specification of the component, which the serial controls.)
Message 4 of 9
(7,457 Views)
Can it be a software mistake for the controlling of the RS232 serial interface?
Message 5 of 9
(7,427 Views)
please follow the instructions in the manual “Getting Started with CompactRIO and LabVIEW” to reinstall the software on your NI sbRIO-9612.
It’s explained in detail in the chapter “Installing Software on and Configuring the Controller” on page 6
http://digital.ni.com/manuals.nsf/websearch/C9721DD0A5F989CE8625760A007D4D1B
Regards
Ulrich
AE NI-CER
Message 6 of 9
(7,416 Views)
Accepted by wilburwu
here is how I did to solve the problem:
I replaced all the timed loops in sbRIO with the while loops (time interval inclusive)
And that's it! It looks like the timed loop cause the problem in some unknown way. The same thing I've also seen on the FPGA.
My LabVIEW is 8.6 and NI RIO is 3.1.
Message 7 of 9
(7,358 Views)
Hi, Wilburwn
I have a PXI RT target, and I also use timed loop for determining application. I recieved the same error as you.Do you have any other method for repairing this problem except removing all timed loop? Because I really need the timed-loop.
Message 8 of 9
(6,318 Views)
Message 9 of 9
(4,704 Views)
