scale multiple objects with front panel
I have so many objects in the front panel. But I want only to scale some of the objects (ie need to keep the button's size as it is). When I'm trying to select the option 'Scale object with the pane' for each objects , it is available only for a single object.This option is not showing after that. Is there any other method to do this?
(3,508 Views)
Accepted by jawadtld
Go here, this information will help you solve Your problem
http://digital.ni.com/public.nsf/allkb/048C31D73E8EC91286256E440063E1BB
BR
Certified LabVIEW Architect (CLA)
(3,493 Views)
