scan from camera and store in excel
Hello everyone
i am having problem with my VI
actually i have to get the data in this format
18/03/2014    2:10     PIC first comparmtnt       TP022216         25/03/2014        Enter manually
but i am getting it like this
18/03/2014    2:10     PIC first comparmtnt                            25/03/2014        Enter manually
18/03/2014    2:10                                           TP022216         25/03/2014        Enter manually
like i am not getting it in a row itself
should i share my VI
(2,537 Views)
Hi Zahkay,
One recommendation I would give is to probe your code and/or run it in highlight execution mode. This will allow you to see the string that is going into your tdms file. I would put in some way to monitor the string array input into the TDMS write. It may be tat the data is not getting passed correctly from one case structure to another. Some other tips are to use shift registers instead of feedback nodes if you just want to pass data from one loop iteration to another.
Paolo F.
(2,466 Views)
Dear sir
i am really, i didnt see your reply. I didnt had notifications..
I am able to solve this issue sir no problem.
But now i am having a new problem concerning my coding. Should i say it
here or i should open a new topic for it. It is actually the implementation
of arduino to labview
thank u
(2,433 Views)
