scan from string error 85
I am having trouble using scan from string function. For some reason I can't separate the string from the number. I get error 85.
(6,350 Views)
We can't really diagnose the problem if we don't know what's going into it...
Bill
CLD
(Mid-Level minion.)
(6,342 Views)
Appologies.
When input string is PID1234 I expect the following outputs:
String output = PID
Numeric output = 1234
Instead I get an error 85
(6,335 Views)
Accepted by drakkar
%s is going to grab everything, instead grab the non-digits followed by a number using this format string : %[^0-9]%d
(6,327 Views)
Use "%[^0-9]%d" for your format string.  This will tell the first string output to stop when it finds a number.
EDIT: Well, better late than never...
(6,321 Views)
