scan mode error when using NI 9234 with cRIO 9075
Hello
I am new to cRIO 9075 and NI 9234 and NI 9227
I am trying to use it to measure current and vibration of a motor
later I am going to control the motor using NI 9263
Please find my VI andscreen shot of error and please let me what is wrong.
(3,250 Views)
The LabVIEW project file doesn't actually contain any VIs, could you attach the VI that is loading with errors as well?
(3,233 Views)
Hello Jacbson
Thank for your reply
I am trying to use the Find Example with my new added target cRIO 9075
I opened the project.
Saved it including all files.
I added new target.
I removed the oringinal target from project and I kept my added target.
Of course I dragged and droped the two VIs each one under his position either chassis or FPGA
Please help to remove he broken errors as per attached zip ffilecrio-example923x errors.png
(3,215 Views)
