scan rate and samples for FFT affecting dt
Accepted by M.Warlow
Mike,
You can get 1 Hz resolution with a 5 Hz update.  What I described earlier was a way to do the FFT once per second.
If you want to update the FFT 5 times per second, just do the FFT after each acquisition.  You still need to accumulate 1 second of data in the circular buffer.
Suppose you have 0.2 second acquisitions numbered 1 through 5.  An FFT on {1,2,3,4,5} will give the 1 Hz resolution.  0.2 seconds later you have acquisition 6.  Then do FFT on {2,3,4,5,6}.  Some of the data overlaps so rapid changes will not show up in the transformed result immediately, but that is a consequence of the resolution you have selected.  This is called a "sliding window" calculation.
Lynn
Message 11 of 21
(1,736 Views)
Hi again,
Many thanks for your time and effort you have shown in helping me out here.
One final question as i now understand what you have said so far, but how would i create a circular buffer for the smaller samples.
Any chance you could put a small pic up showing how its done?
Again , thanks for your help
Mike
Message 12 of 21
(1,729 Views)
Mike,
I have been pretty busy today.  I will try to post something tomorrow.
Lynn
Message 13 of 21
(1,713 Views)
Thanks Lynn, look forward to getting this working 🙂
Cheers
Mike
Message 14 of 21
(1,699 Views)
If you want to update with 5 Hz and show 1 second of data, you could use a waveform chart, and pass the content of this chart to the FFT function
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 15 of 21
(1,691 Views)
Hi, i've tried that, but most probably incorrectly as it still did not work, could you provide a quick diagram if you have time
Many thanks
Mike
Message 16 of 21
(1,684 Views)
Hi all (again!) 🙂
I think i may have got it working using the chart as suggested, below is what i have done , all seems to work fine - is this what you guys meant?
This was for 10hz and a history of 10 samples
Cheers
Mike
Message 17 of 21
(1,678 Views)
I made this a quick example. The chart is strip-chart. The chart history length is set to 5000 so it will always contain the last second of data. As note this method is OK then you are using a relatively small chart history length, and do not update to often. A large history length and high update rate will hog system recourses.
Message Edited by Coq Rouge on 12-03-2009 12:45 PM
Message 18 of 21
(1,673 Views)
hi, not sure if there is supposed to be an image attachment?
Just looking at my example too..i think i probably have to add from earliest to latest time wise  not from latest to earliest as i have done?, or does it not really matter?
Message 19 of 21
(1,668 Views)
I posted a full VI not a picture
Message 20 of 21
(1,666 Views)
