scrollable sub panel
I have an application that consists primarily of a tab control.  On a portion of one of the tabs, I have various controls: check boxes, radio buttons, text and numeric fields. (see attached snap of tab) These are used to access 8 different registers.  I need to expand this to access 32 registers but I don't want to grow the tab to be that large. Not all 32 need to be visible at one time.
I was thinking some sort of scrollable sub panel would be nice where you can view 8 registers at a time, but I don't know how to create one.  I read other similar posts that recommend using a splitter bar but I only need this capability on one of the tabs not the whole thing.
Any suggestions?
I'm using LV 8.2.
Thanks.
(4,242 Views)
Accepted by JohnSantaFe
Perhaps you could make each row a cluster, and have an array of clusters.  Then drop a vertical scrollbar control on the diagram and have the value of that scroll bar change the index of the cluster array.
(4,221 Views)
Thanks!
I implemented an array of clusters and that works well.  I didn't go as far as using a separate scrollbar and controlling the index. I'm able to use the array's built in scroll bar feature to implement what I needed.
However, using the array's scrollbar, when I scroll past the active members of the array, there are additional non-active array elements that are grayed out.  Is there a way to have an array not show the grayed out 'potential' array members?
Thanks.
(4,193 Views)
I don't think you can.  That is why a separate scroll bar should be used to allow you to set the indices to only show you the array elements with values.
(4,190 Views)
