search 2d array and replace
Ooooh, you're gonna get some criticism on the forums for that one.
Sequence structures and local variables Smiley Surprised
Cory K
Message 11 of 18
(2,703 Views)
Oooh, yep.  Definitely needs criticism.
Actually, its not bad and the code is clean.
I would make one recommendation and eliminate the local variable "Array" that was just inside and after the flipping functions.  Why?  Because you have a data set as an input, and you've effectively changed the dataset appearance on your front panel by writing the flipped array back to the local variable.  Keep clicking run and you see your control array flips back and forth and the resulting data changes because you've changed the input data set for the next time the VI is run.  The results are based on what the array looked like when the instant the VI started, and not what it looks like when the VI ended.
Message Edited by Ravens Fan on 03-06-2009 11:52 AM
Message 12 of 18
(2,700 Views)
thank you guys for the great learning experience!!!!
Message 13 of 18
(2,691 Views)
actually, I take that back...
it doesn't work completely...
it only work for index 0.
so any duplicates after that..it doesnt look at?
Message 14 of 18
(2,671 Views)
Accepted by Giangliang
Try a shift register on your outer while loop as well.
Also, your stop condition is wrong.
You want the loop to stop when the size of the array is less than or equal to i +1.  Right now you have it when the array size is greater than i, which it will be right on the first iteration because i=0
Message Edited by Ravens Fan on 03-06-2009 02:03 PM
Message 15 of 18
(2,661 Views)
woww..cool..thanks....
hmmm..i am still surpised it took this many code to do something that small..
maybe OpenG was a better option?
Message 16 of 18
(2,650 Views)
ok...after i got back from lunch..the program is not looking as disired..
it doesn't delete all rows with duplicates...
it only delete the rows with the first elements that it sees..
I made this change..
i think you had it as...
if N > i (i=1) then stop..
and that causes the while loop to stop and i dont think we want that.
Message Edited by Giangliang on 03-06-2009 03:59 PM
Message 17 of 18
(2,642 Views)
You're right.  I got to making the change on the comparison , but I forgot to reverse the inputs on the comparison.
I think I know why there is an issue with some duplicates.  I rthink it occurs when there are some consecutive duplicates.  It is in the inner For Loop.  Let's say you have row 0 (after transposing), and there duplicates on row 3 and 4.  It gets to row 3, and deletes it, Now row 4 becomes 3.  But then the next instance goes to row 4 (because the calculation is based off the For Loop's i terminal), having completely jumped over the new row 3.
See the attached changes.  In the False case is an increment +1 function.  So if it finds a duplicate and deletes it from the array, it stays at that row.  If it sees it isn't a duplicate, only then does it increment the index.
Message Edited by Ravens Fan on 03-06-2009 09:47 PM
Message 18 of 18
(2,618 Views)
